Dimplex Quantum storage heater flex cable routing
22 Jan 2012
UK
Hi all,
I have just received 2 Quantum storage heaters and have installed them. My peak supply is on the right and off-peak on the left.
The cables from the heater both exit on the right. The older heaters had clips underneath to accommodate getting the flex to the other side if needed. It seems these don't, and there is nothing to cable tie them to.
Has anyone else had the same issue and have a solution? I don't think sticky pad cable holders will work due to the heat, and I don't want to drill any holes to make supports.
Tim
sticky pad holders might work if you remove the sticky pad and use an appropriate glue. Or use a length of minitrunking below the heater along the top of the skirting board if there's room.
Thanks Owain, mini trunking will be fine. Not sure why I didn't think of that!!
