DIPLOMAT ADP8322 Dishwasher Stuttering!!!
25 Mar 2010
I have what seems to be stuttering coming from the the pump when i run any cycle above 40 Degrees. It's fine on the pre-rinse and rapid cycles and when draining is also fine. Any help would be gratefully recieved.
Regards Chris
This sounds exactly like the problem I am having with my adp8322. Anybody have any ideas?
thanks
mark
Sounds like you may have a failing circulation motor or a piece of glass rattling around in the impellor housing. Is the service number 8545 000 15819? (model details usually laser engraved on the door lip).
Thanks for that info. The service number is 8545 000 15810.
Is it easy to get to the impellor housing?
If you have an Askoll type circ. pump be aware they have a pretty poor reputation. The resistance you measured doesn't tell you anything other than the winding isn't O/C. Try hotwiring it to see how it runs dry, then empty a litre or two of water in the machine & run it loaded.
