Hi,I have a Diplomat ADP8322 dishwasher that does not heat the water.The cycle starts then stops after about 2 mins doesnt give any error codes.Any advice would be gratefully received.
Your machine does tell you a no-heat error code, you just haven't recognized it. Display models show F3. LED models show a repeated series of 3 flashes on the start button. It can be caused by the following: faulty heater (obviously), defective heater relay (new pcb required), break in wiring, or defective NTC (least likely).
Flow meter failed/defective, inlet valve defective, or inlet hose blocked.
Scroll to the top of this page & click search. Type F7 in the search field, select appliance section & hit the search button. You'll find dozens of good posts on how to rectify this issue
