diplomat dishwasher
23 Oct 2006
Hull
i have a diplomat dishwasher model ADP8322 and am getting fault intermitent bleeping and 4 flashes on start light all it seems to do is keep pumping out any ideas please
4 flashes indicates a draining fault.
Take out the mesh filter and look at the black grid in the bowl, make sure it's clean and free from crud. Careful when you clean it though as it's easily punctured.
ok i checked the filters and the black grid all clean and clear and all water gone out but still pumping and still getting 4 flashes and beeping
help Diane
OK, it must be misreporting. If it pumps all the time it sounds like a flooded base. Tip the machine backward slightly and see if any water runs out of the bottom.
Cancel the alarm and try again.
ok there was water in the bottom originally as one of the hoses had split but that was replaced and it has been like this since the base is now dry and clear and there is no water in the machine still getting beeping and 4 flashes
