I have one of these...
http://www.diynot.com/diy/threads/diplomat-adp8902-dishwasher-stuck-in-drain-cycle.130436/
Diplomat/Smeg, underside as per the pic in the other thread.
It seems to work OK in rinse mode, cold water rinse for about 20 mins, then drains off. But as soon as I try any of the other settings, it gets stuck in rinse mode, and continues in a loop over and over. After the rinse cycle, it does a double beep and restarts the rinse cycle ad infinitum! It appears to be draining out ok, and the wash pump is cycling water round.
I've tested the following, Door thermistor, reading goes down when heat is applied, so assume all is well. Heater unit, tested the terminals where the L&N wires go in, get a reading in cont. mode. I think no reading at all means it's dead, so that should be ok too(?)
What else to check, any other thermostats I need to check?
Just to confirm, no leaks underneath.
