I'm just looking for a bit of advice on something that is probably a bit unusual.
I've just removed my old hot water tank and I've replaced it with a Sunamp device. There's no point in connecting the hot water circuit to the Sunamp as the boiler ( very old, gravity, vented ) flow isn't sufficient for the Sunamp. I'm just going to run the Sunamp from electricity ( PV & cheap overnight grid ) until I retire the boiler and replace it with a heatpump next year at which point it'll be connected to the heatpump.
At the moment, the hot water is set to off ( in the Hive app ) and the hot water circuit flow and return pipes are capped off. The tank thermostat is just tucked away. Can I just leave it at that until the heatpump comes along or should I do more e.g. connect the hot water flow and return together ( just in case the three port valve operates for some reason ) and/or set the cylinder thermostat to a low temperature and maybe attach it to the heating flow? Or maybe I remove the 3 port valve and replace it with copper pipe...
I'm just looking for the easiest solution that isn't going to adversely affect my heating system when I switch it on for winter.
Thanks in advance.
Thanks in advance.
