Hi, new here and hoping someone can help me with this problem.
BEKO DWD 8657
Pressure spec: 0.3-10.0 bar.
First Symptoms:
Letting in water constantly.
Flood control? Nonexistent, flooded neighbours house instead of going into drain cycle.
Secondary Symptoms:
Went into constant drain cycle after a few uses, I was turning tap off between uses, was told it was OK to do so.
Newest Symptoms:
Letting in water constantly until programme starts and then lets in zero water. Hangs for hours, well forever.
No one checked inlet pipes filter to start with, it was completely blocked with plastic shearing's from manufacture. Also found metal shearing's in internal filter. I've cleaned them out.
Test:
Open tap, water comes in, constantly.
Press cancel, machine empties and no water comes in.
Start cycle, water comes in then zero water comes in.
If the water pressure was too low to close the valve then water would constantly come in and the cycle starting would have no impact, I think.
Any help appreciated.
Regards
Barry
BEKO DWD 8657
First Symptoms:
Secondary Symptoms:
Newest Symptoms:
Test:
Regards
Barry
