Bosch Exxcel Dishwasher
18 Oct 2010
Cheshire
My Bosch dishwasher has started flooding out water during its wash cycle
The water seems to be coming from underneath
It is not the door seal or the water inlet, and it also seems to drain away quickly when I turn the sselector to reset.
I t seems to be when it is in wash cycle
Can anyone help with some advice
George Brady
Looks like you have a leak.
First of all disconnect and tip the machine forward to get rid of water
in the base.Get it as dry as you can before you start the detective work.
Then the only way to find it is to take to top and side panels off
andwatch it run a cycle.
The common leak areas are between main circulation pump and sump
(you will see a trickle flowing directly under the main pump)
and from the matrix(easier to see)
you obviously need to take care when doing this as electricity
can kill.........[/b]
