Dishwasher help please!!!!!
8 Jul 2006
I have a problem with my dishwasher - the make is 'cookers' but I suspect this is part of a bigger company; it is integrated. It has suddenly stopped working. It will power up, drain some water, and start a cycle but this only lasts for a few seconds before it cuts out. I have taken the filters out and cleaned them, and checked the cold water supply. I there anything else anybody can suggest before I bite the bullet and call somebody out?
Thanks a lot!
Make is actually white-westinghouse DW009. Tonight I stripped it down as much as I could and cleaned it all. By doing this I think that I may have found the problem. There is a removable tray underneath where the electrics are that was full of water, I removed this and emptied the water and now it works again - when I looked underneath there seems to be a float switch which I assume cut the power when this tray is full for protection??? Now my problem is that it seems to have been caused by a small leak in each corner at the front, are there any pointers of where the leaks could be from, and how to solve them? Thanks in advance!
