Dishwasher not cleaning - taking a LONG time to finish
OM2
18 Jan 2007
Salt level is OK.
Just seen a youtube video:
The guy says you just need to replace the filter.
I checked the filter, to one side there is a tiny gap.
So... I can't believe that this TINY gap is what is causing the problem???
Is there anything else I should be doing to check?
Part ordered from Amazon anyway.
(I can cancel order if someone says I should do something else!!)
Thanks.
When I used to have problems like this, it was usually the spray arm had blocked holes.
Run it empty and open it up while it’s running to make sure the arms are revolving. If not check arm holes are not blocked as mentioned above - a small hole in the filter will allow food particles to get into the arms and block the holes. Also, run a really hot wash with a dishwasher cleaner to clear it out.
Done all of those things.
Arms are revolving OK.
Thanks for the replies.
