- Joined
- 18 Apr 2025
- Messages
- 140
- Reaction score
- 4
- Country
Hi All
Belated happy new year. We have an issue with our AEGF343000V10.
Yesterday, we noticed that dishwasher had stopped mid cycle, resulting in circuit switch for kitchen sockets being tripped. At that stage, there was still about a cm of water in the dishwasher.
Just pulled washing machine out to access sockets, check cables etc, and noticed we had a leak from the compression joint which supplies water to the washing machine. Photo attached. Can stop leak with the isolator, so it’s the washing machine end of the valve.
Is it likely that the leak from supply to one appliance tripped the other appliance?
Have swapped over the plugs and confirmed the sockets ok. Also cleaned and dried cables but dishwasher still doesn’t work. (Washer does)
I clearly need to tighten/replace the compression joint in question. (Water off) If it’s the latter, is it a relatively straightforward job?
I was also going to check flood tray for the DW. According to AEG manual it’s at the bottom of the DW and revealed by a few screws. Again, photo attached. Do you concur with this.
All other things being equal, need to establish if there is 1 or two separate issues.
Many thanks
Many thanks
