Hi trying to take down decking and move it elsewhere.. The screws will not come out I bought and extraction kit from screwfix but it didn't work.. What can I do? Cheers in advance.
You'll need more than a screw extraction kit if they really won't shift....using a new and correct size screwdriver, what's happening?
Are the heads shearing off or just rounding?
At the end of the day, expect quite heavy losses if you lever the boards up or have to do much cutting.
John
Hi thanks for your reply we stupidly started trying to remove with the drill and attachment... Now we are using a hammer and the screwdriver it's much better.... Just wish I didn't have such good ideas... Lesson learnt
