ditch at bottom gardn
14 Apr 2006
Hampshire
I have a ditch at bottom garden, (approx 20m long 1/2 metre wide and deep, there is a little water 2 or 3 inches in winter, it seems to be fed partly from the ditch extended up to next doors garden and some seeping along ditch. I wanted to fill ditch and grass over (easier to maintain) Can i fill ditch with gravel and then top soil and grass? Ive heard of french drains and soakaways. Any advice appreciated.
jon
You need to sort out why there is a ditch there, are there ground water problems, i.e. cess pit, soak aways etc
thanks. it appears there are some small springs that drain into it, i can only find one on my side,it is the smallest dribble and even after substantial rain it never gets more than a couple of inches. It appears that the ditch does not drain as it seems blocked beyond my property. I would leave but right against my fence so a real pain to keep clear from weeds etc. so would really like to grass right over to fence and just mow. Any suggestions?
It’s probably home to lovely frogs and things. Leave it alone.
You could put a pipe in, the problem then is you can't see what's going on, and it will eventually silt up.
Post up some photos for suggestions, maybe you could make a feature out of it, or plant something in front.
