We have a patio towards the end of the garden which is approximately 5m x 5m (25m²). It isn't close to the house. It currently has slabs (450mmx450mmx35mm) on it which were laid on a thin base of sand (1mm?) and just soil underneath, the soil is quite compact and hard if stepped on but not as much if you would dig a trowel into it. A handful of slabs have their corners cracked. There is also maybe a 10mm height difference with some as well.
This is a rental property, the landlord is aware of our improvement/fix plans so we have a budget but don't want to make a huge investment into getting this done as we plan to stay here maybe for another 5 years tops. Reason for fixing is as we have a toddler and want to just make the area more level and improve it slightly for the summer.
Initially wanted to DIY this properly (by the book) however now having checked the cost of MOT type 1/sharp sand and cement needed (used https://www.pavingdirect.com/info/patio-paving-calculators/). To get this done properly (delivery charges on top) it just wouldn't be feasible. We already have the replacement slabs (replace damaged ones) and all the necessary tools, except the wacker plate which I would hire for a day or two.
Given I wouldn't be using any MOT type 1 at all, is there any benefit to laying slabs on top of a 30mm mortar full bed? Or should I just stick to using sharp sand and levelling the slabs on top of that as they currently are?
