Do I need these?
15 Jun 2021
Wales
As per the information on the web page, they recommend 12 fixings per 1200 X 2400 board.
I may be wrong - am only a DIY-er :), but that seems a decent number of fixings to avoid uplift.
I don't think it would be the best idea to fix the boards just around the edges!
Edit:
I just reread the webpage, 'For a 2400 X 600 T + G board we recommend 8 fixings per board'
8 Jun 2010
Sussex
Yep but I’m assuming that refers to loose sheets not T&G which will in effect when glued forms a large sheet. Hence only requiring fixing at the edges.
15 Jun 2021
Wales
I suspect that a 4 X 6 m board 18mm thick would probably be quite flexible and could suffer from uplift!
And as the manufacturer recommends 8 fixings for a T&G board, I would be happy to go with that.
But they would say that wouldn't they ;)
29 Jul 2011
Lancashire
There for fixing your insulation down and helping to minimise thermal bridging.
8 Jun 2010
Sussex
sent them back, ill screw some 150mm screws through the lot instead, (yes I know slight thermal bridge).
18mm OSB3/VCL/150mm PIR/18mm OSB3//Edpm
