Do Rad Pipes Need To Be Perfectly Vertical?
13 Dec 2019
So took my radiators off to do redecorating (and drained system). I'm now looking to put all rads back on apart from the bathroom one. I noticed when re-attaching the rads, the pipes that connect aren't perfectly vertical. If I shove the rad to one side then the left side connecting pipe becomes 100% vertical but the right side isn't and vice/versa... Does this matter?
I can't remember if they were perfectly level when I took them off.
Also, how much water should I put in the system when re-attaching rads? Should I put in 1/2 between 0 and 1 - and then open up a rad one by one and ensure no leaks when water enters the rad?? ..... I don't want to put too much water and pressure in the system at once.
Just bend it straight man! The floorboard probably held it straight and it sprung out of vertical when the board was taken up.
Yup, I'd be tempted to give it a wiggle straight too, just be careful to support it as you don't want it to bend at the entry to the valve.
Its fine.
