Hiding vertical pipes behind a vertical radiator
2 May 2013
Bedfordshire
Considering getting a vertical rad in one of our rooms as part of a CH upgrade.
Two reasons:
1) will free up more space in the room
2) may be a way of hiding vertical pipes that run down from the ceiling rather than having the messy job of having them chased in the walls.
Only a small bit of piping would be seen above the rad, and I could live with that.
Only issue is that the pipes (15mm i think) in their current pipe clips extend 30mm from the wall, and most vertical rads seem to only have about 20mm - 25mm space behind them.
Im presuming there are clips that could pull the pipes closer to the wall?
Would be interested in thoughts on this idea.
Cheers
10mm PB or Pex.
Single-piece copper saddles:
