This might be a stupid question ...(have tried a web search but can't find an answer - so either a really stupid question
or not wording it correctly ...)
If you had a water pump fitted (vented cylinder and header tank) and there was a power cut or the pump failed would the water 'cut off' or would it still come through just at a lower (normal) pressure/flow rate?
