Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Its great reading the bickering between you two.
I followed the link to the Hepvo plumbing technical design guide. They do state, ‘ the inclusion of an air admittance valve in the waste system is no longer necessary’.
So should this matter be directed to Hepvo?
HepVo traps can replace the AAV. That is clear. It is clear many so-called professionals here don't know about them (introduced about 8 years ago and won an award). I know many homes that have used them on a one stack house WITHOUT a vent. The local council will tell you the regs on stack venting – usually every 4th or 5th house needs a vent. Hard luck if you are the 5th. This house had no vent just an AAV in the loft. The stack from the wc into the loft can be taken away if HepVo traps are used on all other sanitary appliances.
It is clear in their documentation. Many BCOs have never heard of HepVO traps. If the BCO says no, contact Hepworth and they will send the BCO a letter. A BCO can’t go against the regs either.
Hi there, thanks for all your help. I have (at last) put a t section on the outside wall just after the rest bend and put in a stack. Needed to dig up a bit of concrete and dig round the pipe, but pleased with the end result. I have put the polypipe valve on the end, is this ok to use outside?
Polypipe valve = air admit. valve ? not too clever outside because of frost causing valve to stick by freezing the condensation inside ........but Hey we`ve got global warming now maybe no more frosts
Venting the sewer isn't an exact science. In either a theoretical or an anecdotal decision, Building Control may well have passed the installation without a vent and without any subsequent problems.
For example, if the properties both sides of you were vented, then it's unlikely enough that any positive pressure will develop underground.
BTW, I know you're probably about to announce that none of the houses in your entire street has a vent, but that doesn't change my basic point.
