Does it matter if a radiator is much too big?
17 Apr 2013
I am getting a new boiler fitted and want to change a couple of radiators whilst I'm at it. My hall/landing currently has a radiator with an output around 4700 BTU which according to online calculators should be about right but it doesn't heat the room as much as I would like. It could be because my house is an old nofines ie has solid concrete walls. Would there be any problem fitting say a 6500 BTU or will it cause the system to be inefficient. If so would fitting a thermostat valve be the solution?
Bigger is always better, and can be more efficient. TRVs are always a good idea
You'll be in little Scotland then? For the installers sake I hope he hasn't got to make a new flue hole.
Those walls are like bullets :LOL::LOL::LOL:
Thanks for your replies all. That has reassured me that I can fit something significantly bigger without problems.
