Hi all,
I recently (4 weeks) ago had tiles laid on an anhydrite screed floor.
I am now able to put the UFH on 'minimum' for one week and then slowly increase the temperature.
The TMV on the manifold has 20 deg as it's lowest setting (20 - 70 is the range).
However, my stat is sitting around 19 - 22 deg depending on the heating in the rest of the house.
My question is... if I turn up my stat to (say) 25 deg... will my UFH still only sit at 20 deg because the TMV is restricting the temperature of the water going into it?
That's how my tiny little brain *thinks* it should work but I wanted to check with the experts before I do it as I don't want to cause "thermal shock" and make the tiles lift?
Thanks for any help you can give me
