Hi, I'd like to know whether I need to replace the orange domestic hot water gate valve picture below. It spins aimlessly when I try to close it and seems to be stuck in the open position. This is a problem as I'd like to replace a washroom basin. Does the whole valve need replacing or is it just the threaded bit that screws into the valve that needs changing?
The other 22mm gate valve in the picture (red) was replaced a few months ago as it was stuck (not even spinning). I asked a plumber to do it for us as the new valves are shorter, so we needed an extra lenth of pipe + straight coupling and I didn't want to risk doing a poor job of it and being without running water.
This time around, I'll do it myself if the entire valve doesn't need replacing.
Thanks.
Thanks.
