Does this kind of lock exist?
Are the comments above referring to the same type of lock and if so, is it the type pictured in post #12? If so, that one seems to need a handle, which I definitely don't want.
It has the ability, but not a need, to fit a handle.
If you don't want to fit a handle, don't.
By chance, my old one, stamped "1989" recently suffered a broken return spring last week.
So I bought a new one, and will swap the Detainers from the old lock so keyholders don't need to change keys.
And here it is...
You can see the date stamp. In daily use for 37 years.
Security screws are not removable with any type of screwdriver . 70mm is for thicker gates , shorter lock barrels are available .
Thank you for the replies.
Can the UNION HD72DNL be fitted on the LEFT side of the gate and the gate PULLED shut without the key? So on the other side, it would be on the RIGHT side of the gate and the gate PUSHED to close without the key.
Don't know, I haven't got one. I expect they have a help line, though.
It is normal these days for locks and latches to be reversible for use right handed or left.
I had read that it was reversible, but didn't realise it referred to the actual latch itself. I was thinking of the whole lock, so thank you for pointing that out.
