Hi
Bought a set of LED lights for my wardrobe (http://www.screwfix.com/p/lap-flynn-recessed-led-kit-white-15mm/41346) but want to add a door switch so they come on automatically.
I was going to split the wire going from the transformer to the mains plug (i.e. 240V) and run through a 'push to break' switch. Is this the best device, or should I be looking for a sensor switch (I was looking at a Hafele sensor, but not clear if this would be compatible with my solution)? Don't want it to waste too much energy when idle, so a solution that minimises this would be good.
Bit of a novice, so would also appreciate confirmation that my proposal is right.
Any ideas / product suggestions would be much appreciated!
