door won,t open on megane
3 Oct 2008
Tyne and Wear
hi there, i have a 51 plate renault megane and the offside rear door won,t open when i press the fob i can hear the door lock open but the door will still not open has anyone got any ideas :?: :?:
I have the same problem did you manage to sort it out and what did you have to do????
you will need to remove the door panel to get at the lock mechanism, sometimes not an easy task im afraid especially if the deadlock is on as you cannot open it from the inside
Is the door stuck closed?
could be the wires in the door gaitor may be perished,you might have to put 12v on the motor itself to get it to open?
