Double Gazing in Timber Frames
15 Aug 2022
Hi all First time poster.....
I have an old 1913 house with lovely timber frame windows, all single panes. Some of the windows are Crittall (opening) and some are fixed panes. There are probably about 50-60 windows in total. The Crittall frames probably don't have enough space for a double glazed pane, so I will replace the single panes as some of them are cracked. However, the timber frames have plenty of space for a 4-12-4 double glazed unit.
I've read much conflicting advice on if this is sensible, how to do it, putty or no putty, putty fronting using butyl, beading etc. So much so, I actually have no idea now if putting double glazed panes in is worth the cost or even possible.
Can anyone help who is experienced in the trade advise me on this ?
Many thanks in advance.
Mike
don't use putty , the putty will crack over time and no sealed unit manufacturer will warranty them. Beading every time. Butyl Strip ( Flexistrip ) is a mute point, in hot weather it can leech around the sealed unit, you would seal around the unit with silicone though. I've seen them put in with Double sized Securtiy tape ( same used as UPVC frames ) , and this works well. Also seen them just siliconed in , but these are a nightmare to get out again when you have to replace them . If you do g replace sealed units in wood , ask for the sealed units to be UNTAPED, as the black tape can hold water , potentially leading to early failure
Thanks @ronniecabers. So just to be clear, what are you saying re the bedding?
I clean the rebate of all putty etc, then put tape or silicone in the rebate for bedding? Then put the glass in, silicone around before beading?
