    Dismiss Notice
Double light switch wiring diagram
Discussion in 'Electrics UK' started by ringolad, 20 Feb 2012.
  1. ringolad
    ringolad
    20 Feb 2012
    Thanks Received:
    Leeds
    Country:
    I am replacing one of the lighting switches in my house and the new switch is marked up differently to the old one. The wiring consists of two red wires + one red loop, one black wire and earth. I attach drawing of the two switches.
    The switch is for working two room lights separately. I bought a 2 gang 2 way switch.
    I tried wiring up the switch and did get one light working but having tried various alternatives, could I have the wrong switch?
  2. ericmark
    ericmark
    27 Jan 2008
    17,927
    Thanks Received:
    1,670
    Llanfair Caereinion, Nr Welshpool
    Country:
    I am sure I have already answered this? Anyway either don't use the L1's or don't use the L2's simple enough just put wires from Com to Com and 2 to L2.
  3. Sponsored Links
  4. TicklyT
    TicklyT
    30 Jul 2006
    3,481
    Thanks Received:
    337
    Hampshire
    Country:
    A common mistake is expecting the top and bottom rows of terminals of switches like your old one to correspond to the two switch units, but they usually don't.
    Have a close look at the back of the old switch and you will probably see a diagonal line moulded into the plastic, probably following the line of the link you have shown between the two 'Com' terminals. That line shows the division between the two halves of the old switch.
    Your new switch has a different layout for the terminals, and the division between the two halves is more obvious.
    Live feed to one 'Com' plus link to t'other 'Com'.
    One switched live to each 'L1'.
    If one or both switches work 'upside down', move the switched live from 'L1' to 'L2'.
  5. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    Plan B would be to put your multimeter (which you should have in exactly the same way that you should have screwdrivers etc) across pairs of terminal on the old switch, and by applying your knowledge of how 2-way switches work (which you must have, as doing electrics without a full understanding of how things work is completely unacceptable), identify which COM goes with which L1 & L2.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
