Hello all and thanks in advance for any advice:
I have an Electrolux double oven (Electrolux EOU43003). I can use the top oven fine, but when I put the fan oven on, it trips the fuse. It starts up and the fan gets going, but after about a second or two, it cuts out and the switch goes on the house's fuse box. If I don't turn the heat up at all, the fan will keep going. Before this happened the first time, there was a burning smell. The oven is not filthy, and the smell was not like a burnt food smell. I don't get any burning smell from using the top oven/grill.
The electric ignition on the separate gas hob above has tripped the electrics for as long as I've had the house, by the way.
I've yet to pull out the cooker, but is there anything obvious that might have caused this? I've swapped out a heating element on a cooker in a previous house, but don't know if that's likely to be the answer this time.
