Downstairs Radiators not Working
11 Sep 2009
Manchester
Hi, I posted a query on this subject a couple of weeks ago about injecting sludge remover into the radiators which I have now done & also put a rad valve with a drain off in place of the existing one. I turned the heating back on and bled the radiators but only the upstairs ones are getting warm - the others are stone cold. I've opened the valves up again (flow & return) so I'm stumped as to what has gone wrong. Any ideas?
Cheers
Neil
probaly airlocked in the drop down pipes from upstairs.
try shutting upstairs rads and running system
Hi, I posted a query on this subject a couple of weeks ago about injecting sludge remover into the radiators which I have now done & also put a rad valve with a drain off in place of the existing one. I turned the heating back on ...
Has the cleaner been sitting in there with the boiler off?
Upstairs rads have trv's. I've put them on their lowest setting. Is that the same as turning it off completely?
Cheers
Neil
shut them to 0
the lowest setting providing the house is warmer than the lowest setting.
Hi, I've done that & downstairs rads are getting warm. Will I need to bleed them again if it's an airlock causing the problem?
