Hi
Hope you can help.
I have noticed that there is some damp in the cupboard under the stairs which is situated against an external wall.
After further investigation it appears that the DPC has been breached in some cases or is only an 1/2 inch or so above ground level. This is the result of the previous owner laying a tarmac drive.
I am thinking of applying bitumen paint on the outside from ground level to the bellcast.
Do you think this is an acceptable approach? Want else should I do?
Cheers,
Phil
Hope you can help.
Cheers,
Phil
