removing tiles etc in a old fireplace i've found that it was basically constructed from putting 2 inch of concrete and ballast directly over a soil base with no dpm. the concrete has cracked over the years- assume due to movement underneath and weight of the fire on top.
i'll be having a stove installed and so digging this out to lay it with a proper sub base and level off but is there any danger around laying a DPM with the heat from a fire, would just several coats of liquid DPM work.
hearth is about 1m x0.6m and is against a party wall of a semi detached.
thanks in advance
thanks in advance
