Drain access Chambers 300 v 450 ???
26 Jan 2012
London
Can anyone give the rule of thumb or building regs about which to use. I have one of these which joins the soil and waste (2 into 1 ) all done in 110mm and then onto the Klargester. It s a 4 bed house and all works fine and both sit at about 600 mm deep. Is this Okay? can i add to the spare inlets in future if i need to ? Thanks
If you are looking for multiple inlets then the 450mm fella trumps the 300mm.
Depth of chamber matters when it comes to size in that the smaller the chamber the more awkward they are to rod at depth. I would say that you may be a tad over the limit at 600mm deep with a mini access chamber.
