Hi there
I hope somebody can help me out regarding this issue we currently have with the foul drains that my property and two others share.
My property and one other which are two years old are built on the grounds of an existing 150 year old property.
The builder of the my house and the other new house renovated the existing house and then sold that one on 2 years ago.
All was well until a couple of months ago when we had a problem with raw sewage overflowing into next doors(150 year old existing) garden.
This as since happened 4 times and i have had to rod the drain out and call in specialists at a cost of £80 a time.
We have since discovered that the foul drainage of the two new houses have been linked into the private sewer of the old house by the builder.
That private sewer then leaves the grounds of the old house and branches into the public sewer which is around twenty meters away across the main road which passes our houses.
Because he owned that old house and it was a private sewer he did not require permission from the local water authority to connect to it and only had to submit plans showing his proposed connection to the private system which the water authority have no concerns over because it is not a public sewer.
Yesterday after a CCTV survey we have discovered that the old private sewer which the two new houses and the existing house use is of an old pitch fiber construction(100mm) and is in very poor condition and requires emidiate replacement.
We have been in touch with the builder of the properties and he says that its our problem even though he made the connection without carrying out a full survey of the sewer system to find out if it was capable of taking the extra load of the two new houses and two extra bathrooms of the old house(gone from 1 bathroom to 9 in total).
I have been in touch with the NHBC and they tell me that we are not covered by their insurance because our new drainage is ok and the drains at fault are existing.
We have had a rough quote to carry out the replacement which is a staggering £20,000 because of the main road.
im sure that the builder should be liable for this as at the end of the day we have all bought new houses from him totaling nearly £900,000.
Can someone with experience of this issue please advise me of my next coarse of action as we are all very worried about the cost implications of resolving this problem.
Thanks very much in advance.
Paul
Paul
