drainage
20 Feb 2011
Middlesex
Hi All
Sorry if this is in the wrong section im new hear.
Im starting an extension at my home, on the side of the house.
I already have a side extension but I want to bring it further forward to the front of the house.
My problem is there is a manhole about 500mm in front of the original extension. I have been told that I should dig a hole large enough to take a new chamber in front of the new extension and cut into the pipe and add the new chamber.
This seems simple enough but my issue is I need to lay an oversite over the area where the existing manhole is. Do I need to remove the lid and all the bricks and connect all the pipework together with fittings sold today or is there any other options which will pass building regs.
I hope I have given enough detail.
All advice would be welcomed.
I think you could leave the existing manhole in place and use a double seal lid and make it 'kinda' accessible.
I'm not too sure about it. Perhaps others might confirm or not?
I assume from your post that the pipe will run under your extension. If so you will need to bridge the foundations over the pipe. Are you certain that this is a private sewer i.e. carrying your waste water only? If it is a public sewer then you will have to involve the local sewer authority, and that could be a nightmare, I know, i'm just coming to the end of the dispute. A civil engineering contractor is now in my back garden replacing the sewer to make it suitable for build over.
A double seal lid seems alot easier. I will look into this.
Its definetly just the private sewer so thats a good thing.
Yeh your right the drain will pass through the footings and I was going to run a lintol accross the pipe to bridge it but not to sure about the proper way of doing it.
Thanks Guys
