I have to install trvs on Radiators in a Bungalow. The system comprises a Baxi Bermuda W Back Boiler and 5 Radiators.
What is the correct method to drain the system or do i only need to drain part of the system?
The Radiators are located in the Kitchen,Hall, Lounge, Bedroom1 & 2. Do i need to install a trv on the Radiator in the Hall? Or use the Rad as a Bypass?
Should i fit a Thermostat in the Hall & if so do i wire it in series with the Time Clock?
Any Help & Advice Gratefully received
Colin
Colin
