Draining a primatic cylinder
2 Oct 2007
Berkshire
Hi, I'm fitting a wet room an I've just gone to take the bath out and there are 2x22mm pipes for the heating running in front of it. I need to drain the system and move the pipes. There's no f and e tank and it's not a sealed system. It's been in about 19 years and apparently it's a primatic cylinder. I've never seen one of these and was sure I was told at college when I dd my apprenticeship that you can't have a pump on a primatic cylinder as it can burst the air bubble? This has a pump? I could be wrong though. To drain the heating I'm going to have to drain the hot water as well aren't I? How does the air bubble reform when it gets filled back up, is there anything I need to do to make it reform or do I just turn the gatevalve back on to the cylinder and let the hot water fill and then vent the rads? Any help would be much appreciated.
Ben
re-fill it slow then the bubble should be ok.
pump what you talking about ch pump or shower pump ?
A central heating pump. I was sure my lecturer said that they could push the water through and burst the bubble. However I am going back 7 years and it was only a passing comment so I could of totally misheard him.
is it on a fully pumped system or only the pumped heating.
primatic's can be fully pumped by putting the pump on the return.
