I am trying to drain down a system which is open vented with an old boiler. I had always understood that there should be two tanks with these systems, one for the hot water tank and one for the heating.
However, there is only one tank and when I've drained the central heating system the tank is still full of water. This tank has two pipes which are curved over the top of the tank which I assume are the pipes to allow for expansion for the heating system and hot water tank. As far as I can tell there is only one outlet pipe at the bottom of the tank which I have traced back to the hot water tank.
Therefore my question is how do I refill the system?
If it's relevant the heating system is single pipe.
Thanks for any replies
