I drained the system by moving each of the motorised valve levers to 'manual'. Then I filled up, adding inhibitor to the feeder tank. '
When I started, the pump was noisy unlike before I drained the system. I tried different speeds for pump, the noise did not disappear. I stopped the system after about 2 or 3 mts so as not to damage the pump
Then I swiched off, moved the lever to manual again and bled one of the downstairs radiators for about 2 or 3 mts, stopping the flow into the feeder tank. I noticed ;at about 12" down stream of the heating valve, the pipe was warm/hot.
I then closed the radiator valve, moved the motor- levers to 'auto' and started the system. No change to noise in the pump. I then checked for any bleeding device on the pump. There seems to be none. If there is one how does it look and how would I operate it.
Or have I done/missed something.
I did the same operation last year, the pump noise was there for a initial period of only 30-60secs and no more.
Any advice is much appreciated.
