drayton lp711 / boiler problems
18 Feb 2011
London
I have a drayton lp711 connected to my boiler. Last night the unit lost all its power. Before I call out an engineer I wondered whether this problem is more likely to be a fuse problem or could the pump have gone. Trying to find information on the net has proved to be frustrating.
Try changing the fuse, or if a modern consumer unit has it tripped, if so and it keeps happening, then you need to find out what is causing it, I would start at the pump.
cheers PVM
changed the fuse and the units back on, but the pumps not starting so i've called my engineer out
