I had a problem in that my radiators weren't getting warm and suspected an acuator problem. I could maually move the lever at the top of the unit and the rads would get warm.
I've fitted a new acuator keeping the locking lever to the right as per instructions. This lever should 'unlock' when the wiring is connected and it recieves a signal 240v. The problem is 'it isn't unlocking' even though the indicator on the side is saying W for hot water the rads are also heating up(the locked position opens both ports) even when the unit is not reciving a signal on the white wire.(rads).
Could this new unit be knackered? I suspect it had been wired in previously as the insulation had been cut back. Any tips gratefully accepted. Keefer58.
