Hello, I have just replaced my Drayton MA1 actuator as the boiler would not switch off. All worked as expected for 3 weeks but now, whenever the heating comes on and the black tab moves to H, it never moves to W or mid position unless I turn the mains off and the actuator seems to release from the H position.
I’ve tried resetting the programmer and turning the thermostat down to its lowest to try turn the heating off put no joy.
Is there any other tests I can do to see if it’s a wiring issue or a switch issue?
I’ve tested the value and it can be moved by hand so belive the issue is in the actuator, which is only 3 weeks old or it’s wiring.
Any guidance appreciated
