I'm sure there are many threads on this subject, but none appear to answer my question. Apologies for any duplication.
I have the above mid position valve fitted into my ‘Y’ plan CH system. It was fitted approx 5 years ago and has operated impeccably until very recently.
I can get a situation where system calling for HW and not CH and get the radiators heating up. This doesn’t happen all the time though.
I have checked the wiring to the valve and this is fine.
When I run through the operation, the actuator appears to move as it should do, however the indicator lever doesn’t move as fully over to the ‘W’ stop as it does the ‘H’
Is this normal?
I removed the actuator, and I noticed a slight rattle as if there was something small loose inside the plastic housing.
Is this normal?
At the same time I checked the movement of the valve shaft. Although it appeared smooth and reached a definite stop at both ends of its travel, the movement appeared to be unequal in both directions. If the shaft was positioned with the flats perpendicular to the exit pipes, the movement was not equal in both directions- almost nothing in one.
Is this normal?
Where should the movement be measured?
What amount of movement should I expect?
Is this normal?
Is this normal?
Is this normal?
