Drilling into beam above window (converted garage) to fit curtain pole.
30 Mar 2010
Rhondda Cynon Taff
Well of course theres plaster on top but buggered if I can drill into whatever is underneath. Is it likely to be a metal beam or something?
I can probably drill about an inch then thats it. Trying to fit a curtain pole.
Any suggestions?
What type of drill and drill bit (and quality) are you using? It will be a steel or concrete lintel. What is the wall construction?
De Walt cordless with Bosch EXPERT HEX-9 Multi-Construction TCT Drill Bit.....
Walls? I guess concrete block with plasterboard. How do I tell?
Im guessing since I'm making zero headway its a steel lintel?
One suggestion I've heard is 3mm hole (with HSS bit) and screw straight into there?
You will need sds drill for concrete beam, for steel you can use self tapping screws. How old is the property!
( you could glue a timber baton to wall and fix to that.)
Yep, SDS and a small pilot will do it. Standard masonry bits in hammer drills will go through the plaster and then they'll go walkabout.
You need Bosh EXPERT CYL-9 Multi Construction Drill Bit and start with a 4mm then a 7 or whatever you need for your plug with this drill bit you will only need a cordless with hammer. If it is metal lintel then you will see filings on the drill, then if metal only drill a pilot hole and then use self tapping screws
Yes, those multi material drill bits are excellent... for a while at least.
I use the Erbauer ones as they're cheaper. I'm not sure if they are sharpenable?
Well, using a HSS bit I managed to drill into it (used a 3.5mm to start). It seemed to be only a few mm thick though?
Is this normal?
Got some 4mm self tapping screws to try in there now. Fingers crossed.
Is this normal?
That sounds lit it is a steel lintal. You are lucky that you found a bit of metal as they are quite often full of holes.
For concrete lintel, sds or combi drill and multi construction bit, building up the bit sizes can help. For a steel lintel drill a hole a fraction smaller than the shank size of the bit. That will help the fixing to self tap
If it is concrete lintel my advice would be to use a four flute SDS bit. You risk hitting the metal rod inside it. The last time I did that with a twin flute bit, it snapped the head. I purchased some Makita Nemesis bits. They cut through the reinforcing bar with ease. The hole didn't deviate.
Edit- I didn't see your previous reply.
You don't really want to be drilling through the rebar. Better a bust bit than a bust lintel.
