Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Not a stud wall, making wall for putting up a microwave mount. Drill gets in about 6cm then can't get much further, with the drill bit lighting up hot orange.
What have I done, what should I do?
A hole 60mm deep should be well deep enough for a quality plastic plug, so long as the diameter hasn't gone oversize....maybe you've hit some particularly hard blue brick in there.
John
Well, I just pushed a little harder and it went through, did an old red brick by the looks of the dust.
The problem now is getting the bloody screw into the plug!
