just a quick question whats the best way to pass pipe through joists is it with a chisel or hole saw etc..?and the best way to drill through a plastic cistern for a new cold feed for a shower pump?
... and don't cut more than an eighth of the the depth of a joist, up to a max of 25mm... seen donuts cutting chunks out of joists to run 40mm pipe before...
