Drilling tumbled marble
30 Dec 2012
Essex
can anyone recommend what to use to drill tumbled marble tiles as I need to mount a towel rail. I heave read about diamond core bits but I'm only needing 6mm holes etc.
Tumbled marble is fairly soft. The arrow head tile drill bits will be sufficient. I would recommend that you pay a little bit more for the better quality ones.
https://www.screwfix.com/p/bosch-expert-tile-drill-bit-6mm/59438
6mm diamond core bits are a paint to use. To begin with you need a guide to stop it spinning off when starting to drill, it needs cooling and the cores often get clogged with the tile core.
Thanks for the advice I do have some of those drill all bits, and I have a set of the arrow heads.
Masking tape where the hole will be and I would tape a bit of cardboard over the area just in case of slips
