Cut a hole through 20mm marble worktop
11 Aug 2008
Hertfordshire
Need to fit two bowl type sinks onto a marble counter. need to cut roughly a 10cm hole through 20mm marble. Would a diamond tipped cutter that fits to my drill be able to cut it, or do i need specialist equipment or need to take it to a firm that cut marble/granite?
If a there is an accesory i can but, can someone recommend one.
Regards
Here, for example. Postage a bit much from Germany but you should be able to get similar from a UK supplier.
thanks for quick rsponse. but i know i can get small 10cm ones, but i need to cut a 100mm hole (10cm), my question was really can i do one this big myself?
Doh! :oops:
You can get/hire 107mm diamond core bits quite easily, I don't know how much tolerance you can deal with. You will need a high torque/SDS drill though as well.
It may be cheaper to contact a specialist granite supplier, and get them out than have to buy all the gear for just the one off job.
