I’m looking for some advice about the best way to deal with my driveway and its drainage, and what would be permitted under current regulations.
My house was built in 2011 and I’ve owned it for just under two years. The driveway is currently tarmac and is quite narrow, with space for two cars parked one behind the other. It has developed a couple of dips, and during prolonged, heavy rain a fairly large puddle collects, so I know I need to get the levels corrected and the driveway sorted.
There is currently one ACO channel drain installed approximately halfway down the driveway, towards the left-hand side, alongside the house. It collects water from the driveway and disappears underground, but I have no idea where it discharges.
I’ve been looking at other properties on the estate and can’t see similar ACO drains on their driveways, which has made me wonder whether mine was added retrospectively by a previous owner.
I’ve already had a few contractors out to look at the driveway, but I’m getting quite mixed information. Some seem to suggest simply connecting additional ACO drainage into the existing downpipe, but when I ask questions about where the water would discharge and whether this is actually permitted, I’m not getting particularly clear answers. I’ve also asked about fully permeable driveway options, but again, I’m struggling to get a clear explanation of what would be required and whether this would be a better solution.
I’m trying to establish the simplest and most cost-effective way of resolving this properly, without undertaking unnecessary work or ending up with drainage that doesn’t comply with regulations.
The options I’ve been considering are:
- Keep the tarmac and install/extend ACO channel drainage. The existing ACO could potentially be retained, with additional drainage installed where needed. However, I don’t know where the existing one discharges. If it connects to an underground pipe serving one of the roof downpipes, would it be acceptable for driveway water and roof water to discharge into the same surface-water drainage system, provided it is a suitable and authorised connection?
- Replace the driveway with a fully permeable surface. Would permeable tarmac or block paving be a better option? Would this remove the need for the ACO channel drain, and could the existing drain simply be capped if it turns out to discharge somewhere unsuitable?
My concern with installing a soakaway is that the driveway is very narrow, with neighbouring drives either side and limited space. I understand that soakaways generally need to be at least five metres from buildings, so I’m not sure whether one would even be feasible.
I’ve also looked through my property searches and can’t see anything clearly confirming that surface water from the property drains to Severn Trent. My water bill refers to wastewater, but I’m unsure whether this confirms anything about surface-water drainage. There is also a highway drainage charge, but I understand this may be separate from drainage from my own roof and driveway.
I’m therefore also wondering how I can establish where the existing roof downpipes and ACO drain actually discharge, and whether there might be an existing surface-water connection that could be used.
Ultimately, I’d really appreciate advice on the following:
- Is it possible to retain an impermeable tarmac driveway and use ACO drainage connected to an appropriate surface-water system?
- Is it acceptable for driveway drainage and roof gutter water to enter the same surface-water drainage system?
- If there is no suitable existing connection, what alternatives are available where there isn’t sufficient room for a soakaway?
- Would a fully permeable driveway be the simplest way of avoiding these issues?
- Would replacing the existing driveway and improving the drainage normally require planning permission or Building Regulations approval?
- How would you go about establishing where the existing ACO drain discharges before committing to the work?
I don’t want to spend thousands replacing the driveway with a permeable option if retaining the tarmac and improving the drainage would be perfectly acceptable.
I’ve already had several contractors out, but I’m finding it difficult to get a clear explanation of the options, particularly around what is permitted and where the water can legally discharge.
Any advice or experience of dealing with a similar situation would be greatly appreciated. Thank you!
