I don't know if it's the warmer weather causing problems. I hung a gate in December 2017. Everything was level and square. There was not enough space for hook and band hinges that I'd bought so I resorted to T-hinges.
When I fitted the slide bolt to lock the gate, it was perfectly level. To the point where there was a little play in the bolt once closed. Yesterday I slid the bolt back (with some difficulty) to open the gate and couldn't reseat it when I'd finished - there was a drop of about half the thickness of the bolt (~5mm).
Is it all to do with the hot weather drying things out?
Some of the tongues of the T&G is now showing where I hadn't painted it with outdoor varnish.
What should I do now the gate doesn't lock?
