Hi
I've recently attempted to remove a radiator from the wall to decorate behind it. I switched off both valves and drained the rad (about 2 1/2 large buckets came off it). However I seemd to have drained the entire system from upstairs as the rads upstairs were full of air - is this normal?
I have since put the rad back on but its currently laying on its side allowing me to turn the rest of the heating on. (the rad on its side however remains off (as both valves are shut)
I have added water back into the system to system and bought pressure back to 2 bars, i've also bled the upstairs rads to remove the air
I recall seeing something about adding inhibitor - where should this be added?
Now then - I will need to put the rad back onto the wall - will I simply have to loosen the nuts either side and put the rad back on, tighten the nuts then open the valves - or so I need to do something else?
